Use the following procedure to enable IPsec on an IPv4 interface.
If you downgrade your software, the current IPsec configurations are no longer supported. You must boot with the factory default settings for IPsec, and then reconfigure the IPsec features.
 - Click IPSec.
 - Click the IPv4 Interfaces tab.
 - In the IpsecEnable column, double-click in the IpsecEnable field, and select enable from the drop-down box.
 - Click Apply.
IPv4 Interfaces tab field descriptions
Use the data in the following table to use the IPv4 Interfaces tab.
 Name  |
 Description  |
 Interface  |
 Specifies the interface.  |
 IpsecEnable  |
 Specifies if IPsec is enabled on that particular interface.  |
