Viewing ACE Port Statistics
Use port statistics to ensure that the ACE is operating correctly.
 - Click Advanced Filters (ACE/ACLs).
 - Click the ACL tab.
 - Select a field on the ACL tab.
 - Click ACE.
 - Click the Statistics tab.
Statistics Field Descriptions
Use the data in the following table to use the Statistics tab.
 Name  |
 Description  |
 AclId  |
 Specifies the associated ACL index.  |
 AceId  |
 Specifies the ACE index.  |
 MatchCountPkts  |
 Specifies a packet count of the matching packets.  |
 MatchCountOctets  |
 Specifies the number of octets of the matching packets.  |
