Edit the existing RSMLT configuration for the local node in the cluster.
- In the navigation pane, expand ConfigurationIPv6.
 - Select RSMLT.
 - Select the Local tab.
 - Select a cell to change the value.
 - Select Apply.
Local field descriptions
Use the data in the following table to use the Local tab.
 Name  |
 Description  |
 IfIndex  |
 Shows the route SMLT operation index.  |
 Ipv6Addr  |
 Configures the IPv6 address of the RSMLT interface.  |
 Ipv6PrefixLength  |
 Configures the IPv6 prefix length.  |
 Enable  |
 Enables or disables RSMLT. The default is disabled.  |
 HoldDownTimer  |
 Defines how long the recovering/rebooting switch remains in a non-Layer 3 forwarding mode for the peer router MAC address. The default is 60.  |
 HoldUpTimer  |
 Defines how long the RSMLT switch maintains forwarding for its peer. The value is a range from 0 to 3600 seconds or 9999. 9999 means infinity. The default is 1800.  |
 OperStatus  |
 Displays the RSMLT operating status as either up or down.  |
 SmltId  |
 Specifies the ID range for the SMLT.  |
 VlanId  |
 Configures the VLAN ID.  |
 MacAddr  |
 Configures the MAC address of the VLAN.  |
 VrfId  |
 Indicates the virtual router ID to which the local RSMLT instance belongs.  |
 VrfName  |
 Indicates the virtual router name to which the local RSMLT instance belongs.  |
