Edit the existing configuration for the RSMLT peer node in the cluster.
 - Select RSMLT.
 - Select the Peer tab.
 - Select a cell to change the value.
 - Select Apply.
Peer Field Descriptions
Use the data in the following table to use the Peer tab.
 Name  |
 Description  |
 IfIndex  |
 Shows the route SMLT operation index.  |
 Ipv6Addr  |
 Configures the IPv6 address of the RSMLT interface.  |
 Ipv6PrefixLength  |
 Configures the IPv6 prefix length.  |
 AdminStatus  |
 Shows the administrative status of RSMLT on the peer.  |
 HoldDownTimer  |
 Defines how long the recovering/rebooting switch remains in a non-Layer 3 forwarding mode for the peer router MAC address. The default is 0.  |
 HoldDownTimeRemaining  |
 Indicates the time remaining in the HoldDownTimer.  |
 HoldUpTimer  |
 Defines how long the RSMLT switch maintains forwarding for its peer. The value is a range from 0 to 3600 seconds or 9999. 9999 means infinity. The default is 0.  |
 HoldUpTimeRemaining  |
 Indicates the time remaining in the HoldUpTimer.  |
 OperStatus  |
 Displays the RSMLT operating status as either up or down.  |
 SmltId  |
 Specifies the ID range for the SMLT.  |
 VlanId  |
 Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1.  |
 MacAddr  |
 Configures the MAC address of the VLAN.  |
 VrfId  |
 Indicates the virtual router ID to which the peer belongs.  |
 VrfName  |
 Indicates the virtual router name to which the peer belongs.  |
