This procedure only applies to the VSP 7400 Series.
Perform this procedure to configure layer 2 I-SID list.
 - Select MultiArea.
 - Select the L2 ISID List tab.
 - Select Insert.
 - Configure the layer 2 I-SID list parameters.
 - Select Insert.
L2 I-SID List Field Descriptions
Use data in the following table to use the L2 I-SID List tab.
| Name | Description |
                                 Name  |
                                 Specifies the name of the layer 2 I-SID list.  |
                                 RangeStart  |
                                 Specifies the I-SID value as the starting range for the layer 2 I-SID list.  |
                                 RangeEnd  |
                                 Specifies the I-SID value as the ending range for the layer 2 I-SID list.  |
