This procedure only applies to the VSP 7400 Series.
Perform this procedure to configure Multi-area SPB layer 2 redistribution.
 - Select MultiArea.
 - Select the L2 ISID Redist tab.
 - Select Insert.
 - Configure the layer 2 I-SID redistribution parameters.
 - Select Insert.
L2 Redistribute Field Descriptions
Use the data in the following table to use the L2 Redistribute tab.
| Name | Description |
                                 Type  |
                                 Specifies the layer 2 Redistribution type.  |
                                 Permit  |
                                 Configures the Multi-area SPB layer 2 I-SID redistribution policy as permit or deny.  |
                                 ExceptListName  |
                                 Configures the name of layer 2 I-SID list. The system does not apply the Multi-area SPB layer 2 I-SID redistribution policy to I-SID values or the range of I-SID values in the layer 2 I-SID list.  |
