Display individual bridging statistics for specific ports to manage network performance.
This command is not available on all hardware platforms.
                               Port Stats Bridge
PORT  IN_FRAME   IN_FRAME   IN_FRAME   OUT_FRAME IN_FRAME  OUT_FRAME IN_DISCARD
NUM   UNICAST    MULTICAST  BROADCAST            xSTP BPDU xSTP BPDU
1/1   179325     0          0          119310    179325    0         0
1/2   187951     26078      42         689486    179324    0         25617
1/3   0          0          0          0         0         0         0
1/4   0          0          0          0         0         0         0
1/5   0          0          0          0         0         0         0
1/6   394        0          0          948942    360       0         0
1/7   4689       0          0          863403    360       0         0
1/8   4369       3206       116        958752    360       0         3995
1/9   0          0          0          0         0         0         0
1/10  0          0          0          0         0         0         0
1/11  0          0          0          0         0         0         0
1/12  0          0          0          0         0         0         0
1/13  179325     0          0          42040     179325    0         0
1/14  187864     0          0          50437     179324    0         0
1/15  0          0          0          0         0         0         0
1/16  0          0          0          0         0         0         0
--More-- (q = quit)
Use the data in the following table to use the show interfaces GigabitEthernet statistics bridging command.
 Variable  |
 Value  |
 {slot/port[/sub-port][-slot/port[/sub-port]][,...]}  |
 Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
