transform-set
crypto-map-ipsec-isakmp-instance
Applies a transform set (encryption and hash algorithms) to site-to-site VPN tunnel or remote VPN client. This command allows you to provide customized data protection for each crypto map can be customized with its own data protection and peer authentication schemes.
Syntax
transform-set <TRANSFORM-SET-TAG> {<TRANSFORM-SET-TAG>}
Parameters
transform-set <TRANSFORM-SET-TAG> <TRANSFORM-SET-TAG> Applies a transform set. The transform set should be existing and configured.
  • <TRANSFORM-SET-TAG> – Specify the transform set‘s name.
    • <TRANSFORM-SET-TAG> – Optional. Specify a second transform set. You can provide multiple, space-separated, transform set tags.
Site-to-site VPN tunnel:
nx9500-6C8809(config-device-B4-C7-99-6C-88-09-cryptomap-test#1)#transform-set AutoVPN
nx9500-6C8809(config-device-B4-C7-99-6C-88-09-cryptomap-test#1)#show context
 crypto map test 1 ipsec-isakmp
  security-association level perhost
  peer 1 ikev2 ikev2Peer1
  local-endpoint-ip 192.168.13.10
  pfs 5
  security-association lifetime kilobytes 250000
  security-association inactivity-timeout 200
  ip nat crypto
Remote VPN client:
nx9500-6C8809(config-device-B4-C7-99-6C-88-09-cryptomap-test#2)#transform-set RemoteVPN
nx9500-6C8809(config-device-B4-C7-99-6C-88-09-cryptomap-test#2)#show context
 crypto map test 2 ipsec-isakmp dynamic
  peer 1 ikev1 RemoteIKEv1Peer1
  local-endpoint-ip 157.235.204.62
  pfs 14
  security-association lifetime seconds 10000
  remote-type none
