insert (mac-acl)
Enables the insertion of a rule in an MAC ACL without overwriting or replacing an existing rule having the same precedence
The insert option allows a new rule to be inserted within a MAC ACL. Consider an MAC ACL consisting of rules having precedences 1, 2, 3, 4, 5, and 6. You want to insert a new rule with precedence 4, without overwriting the existing precedence 4 rule. Using the insert option inserts the new rule prior to the existing one. The existing precedence 4 rule‘s precedence changes to 5, and the change cascades down the list of rules within the ACL. That means rule 5 becomes rule 6, and rule 6 becomes rule 7.
NOT using insert when creating a new rule having the same precedence as an existing rule, overwrites the existing rule.
Syntax
insert [deny|permit] <PARAMETERS> (dot1p <0-7>,mark [8021p <0-7>|dscp <0-63>],
type [8021q|<1-65535>|aarp|appletalk|arp|ip|ipv6|ipx|mint|rarp|wisp],vlan <1-4095>,
log,rule-precedence <1-5000>) {(rule-description <LINE>)}
Parameters
insert [deny|permit] Inserts a deny or permit rule within an MAC ACL
<PARMETERS> Provide the match criteria for this deny/permit rule. Packets will be filtered based on the criteria set here.
For more information on the deny rule, see deny (mac-acl).
For more information on the permit rule, see permit (mac-acl).
dotp1p <0-7> Configures the 802.1p priority value. Sets the service classes for traffic handling
  • <0-7> – Specify 802.1p priority from 0 - 7.
mark [8021p <0-7>,dscp <0-63>] Marks/modifies packets that match the criteria specified here
  • 8021p <0-7> – Modifies 802.1p VLAN user priority from 0 - 7
  • dscp <0-63> – Modifies DSCP TOS bits in the IP header from 0 - 63
Note: This option is applicable only to the MAC ACL permit rule.
type [8021q|<1-65535>| aarp|appletalk| arp|ip|ipv6|ipx|mint| rarp|wisp] Configures the EtherType value
An EtherType is a two-octet field in an Ethernet frame that indicates the protocol encapsulated in the payload of the frame. The EtherType values are:
  • 8021q – Indicates a 802.1q payload (0x8100)
  • <1-65535> – Indicates the EtherType protocol number
  • aarp – Indicates the Appletalk ARP payload (0x80F3)
  • appletalk – Indicates the Appletalk Protocol payload (0x809B)
  • arp – Indicates the ARP payload (0x0806)
  • ip – Indicates the IPv4 payload (0x0800)
  • ipv6 – Indicates the IPv6 payload (0x86DD)
  • ipx – Indicates the Novell‘s IPX payload (0x8137)
  • mint – Indicates the MiNT protocol payload (0x8783)
  • rarp – Indicates the reverse ARP payload (0x8035)
  • wisp – Indicates the WISP payload (0x8783)
vlan <1-4095> Configures the VLAN where the traffic is received
  • <1-4095> – Specify the VLAN ID from 1 - 4095.
log Logs all deny/permit events matching this entry. If a source and/or destination MAC address is matched (i.e. a packet is received from a specified MAC address or is destined for a specified MAC address), an event is logged.
rule-precedence <1-5000> rule-description <LINE> The following keywords are recursive and common to all of the above parameters:
  • rule-precedence – Assigns a precedence for this deny/permit rule
    • <1-5000> – Specify a value from 1 - 5000.
Note: Lower the precedence higher is the priority. A rule with precedence 3 gets priority over a rule with precedence 10.
  • rule-description – Optional. Configures a description for this deny/permit rule. Provide a description that uniquely identifies the purpose of this rule (should not exceed 128 characters in length).
nx9500-6C8809(config-mac-acl-test1)#deny 11-22-33-44-55-66 11-22-33-44-55-77 any rule-precedence 1
nx9500-6C8809(config-mac-acl-test1)#deny host B4-C7-99-6D-CD-9B any rule-precedence 2
nx9500-6C8809(config-mac-acl-test1)#show context
mac access-list test1
In the following example a new rule is inserted between the rules having precedences 1 and 2. The precedence of the existing precedence ‘2‘ rule changes to precedence 3.
nx9500-6C8809(config-mac-acl-test1)#insert permit host B4-C7-99-6D-B5-D6 host B4-C7-99-6D-CD-9B rule-precedence 2
 deny host B4-C7-99-6D-CD-9B any rule-precedence 3
