off-channel-scan
      interface-config-radio-instance
Enables off-channel scanning on
            this radio. This option is disabled by default.
Channel scanning uses the access point‘s resources and is time consuming. Therefore, enable this option only if the radio has the bandwidth to support channel scan without negatively impacting client support.
      Supported in the
                following platforms:
                - Access Points — AP310i/e, AP410i/e,
                        AP460i/e, AP505i, AP510i/e, AP560i/h, AP7522, AP7532, AP7562, AP7612,
                    AP7632, AP7662, AP8432, AP8533
off-channel-scan {channel-list|max-multicast|scan-interval|sniffer-redirect}
         off-channel-scan {channel-list [2.4Ghz|5Ghz]} {<CHANNEL-LIST>}
         off-channel-scan {max-multicast <0-100>|scan-interval <2-100>}
         off-channel-scan {sniffer-redirect tzsp <IP>}
      Parameters
                     | off-channel-scan | Enables
                        off-channel scanning and configures related parameters. These parameters are
                        optional, and the system configures default settings if no values are
                        specified. |
                     | channel-list
                        [2.4GHz|5GHz] | Optional.
                        Selects the 2.4GHz or 5GHz access point radio band. Restricting off channel
                        scans to specific channels frees bandwidth otherwise utilized for scanning
                        across all channels.
                           2.4GHz – Selects the 2.4
                              GHz band5GHz – Selects the 5.0 GHz
                              band |
                     | <CHANNEL-LIST> | Optional.
                        Specifies a list of 20 MHz, 40 MHz, or 80 MHz channels for the selected band
                        (the channels are separated by commas or hyphens) |
                        specified. |
                     | max-multicast
                        <0-100> | Optional.
                        Configures the maximum multicast/broadcast messages used to perform OCS
                           <0-100> – Specify a
                              value from 0 - 100. The default is 4. |
                     | scan-interval
                        <2-100> | Optional.
                        Configures the scan interval in dtims
                           <2-100> – Specify a
                              value from 2 - 100. The default is 20 dtims. |
                        specified. |
                     | sniffer-redirect
                        tzsp <IP> | Optional.
                        Captures and redirects packets to a host running a packet capture/analysis
                        tool. Use this command to configure the IP address of the host.
                           tzsp – Encapsulates
                              captured packets in TZSP before redirecting to the specified host
                                 <IP> – Specify
                                    the destination device IP address. |
nx9500-6C8809(config-profile-510TestProfile-if-radio1)#off-channel-scan channel-list 2.4GHz 1
nx9500-6C8809(config-profile-510TestProfile-if-radio1)#show context
 interface radio1
  data-rates b-only
  mesh client
  guard-interval long
  aggregation ampdu tx-only
  aeroscout forward
  ekahau forward ip 172.16.10.1 port 3
  non-unicast tx-rate bss 1 dynamic-all
  non-unicast tx-rate bss 2 highest-basic
  non-unicast tx-rate bss 3 highest-basic
  non-unicast tx-rate bss 4 highest-basic
  non-unicast tx-rate bss 5 highest-basic
  non-unicast tx-rate bss 6 highest-basic
  non-unicast tx-rate bss 7 highest-basic
  non-unicast tx-rate bss 8 highest-basic
  non-unicast tx-rate bss 9 highest-basic
  non-unicast tx-rate bss 10 highest-basic
  non-unicast tx-rate bss 11 highest-basic
  non-unicast tx-rate bss 12 highest-basic
  non-unicast tx-rate bss 13 highest-basic
  non-unicast tx-rate bss 14 highest-basic
  non-unicast tx-rate bss 15 highest-basic
--More--
