connection-capability [ftp|http|icmp|ip-protocol|ipsec-vpn|pptp-vpn|sip|ssh|tls-vpn]
connection-capability [ftp|http|icmp|ipsec-vpn|pptp-vpn|sip|ssh|tls-vpn] [closed|open|unknown]
connection-capability ip-protocol <0-255> port <0-65535> [closed|open|unknown]
connection-capability |
Configures the connection capability element in this passpoint policy |
ftp |
Specifies the protocol type as FTP. Configures TCP port 20. |
http |
Specifies the protocol type as HTTP. Configures TCP port 80. |
icmp |
Specifies the protocol type as ICMP |
ipsec-vpn |
Specifies the protocol type as IPSEC VPN. Configures ESP and UDP ports 500 and 4500. |
pptp-vpn |
Specifies the protocol type as PPTP VPN. Configures TCP port 1723. |
sip |
Specifies the protocol type as SIP. Configures TCP port 5060 and UDP port 5060. |
ssh |
Specifies the protocol type as SSH. Configures TCP port 20 |
tls-vpn |
Specifies the protocol type as TLS VPN. Configures TCP port 443. |
port <0-65535> [closed|open|unknown | After specifying the protocol type, specify the
port (associated with the selected protocol) and its status.
Note: When the connection capability element is not configured, the
hotspot does not return the element in an ANQP capability request and
ignores any ANQP query for the element.
ip-protocol <0-255> |
Identifies the IP protocol by the protocol‘s number. For example, for SMP (simple message protocol) specify 121. |
port <0-65535> [closed|open|unknown] |
After specifying the IP protocol type, specify the port number.
After specifying the port number, specify the port status.
Note: When the connection capability element is not configured, the hotspot
does not return the element in an ANQP capability request and ignores any
rfs4000-229D58(config-passpoint-policy-test)#connection-capability 1 ip-protocol 2 port 10 closed
rfs4000-229D58(config-passpoint-policy-test)#show context hotspot2-policy test access-network-type chargeable-public connection-capability ip-protocol 2 port 10 closed 3gpp mcc 310 mnc 970 3gpp mcc 505 mnc 14 rfs4000-229D58(config-passpoint-policy-test)#
no |
Removes the configured connection capability element on the passpoint policy |
