rssi-interval-duration
Configures the interval, in seconds, at
which dedicated sensors scan channels for RSSI assessments and send the RSSI data obtained to
a specified server resource
- Service Platforms — NX 75XX, NX 95XX, NX 96XX, VX 9000
Syntax
rssi-interval-duration <1-60>
Parameters
| rssi-interval-duration <1-60> |
Configures the RSSI interval duration in seconds. This is the interval at which
the sensor scans channels for RSSI data and forwards the data to a dedicated server
resource. The server calculates real-time locations of Wi-Fi devices based on the
this data.
- <1-60> – Specify the RSSI
interval duration from 1 - 60 seconds. The default is 1 second.
The channels scanned for RSSI assessment depends on the scan-mode selected.
For more information, see scan-mode
and custom-scan.
Ensure that
the server‘s IP address or hostname has been configured in the access point
sensor‘s RF Domain context.
nx9500-6C8809(config-sensor-policy-test)#rssi-interval-duration 30
nx9500-6C8809(config-sensor-policy-test)#show context
sensor-policy test
scan-mode Custom-Scan
custom-scan channel-frequency 2412 width 20MHz scan-weight 1000
custom-scan channel-frequency 2417 width 20MHz scan-weight 1000
