asn (bgp-router-config)
Configures the ASN. The ASN represents a group of routers under the same
administration and using IGP and common metrics to define how to route packets. In short the
ASN represents all routers within an AS.
Syntax
asn <1-4294967295>
Parameters
asn <1-4294967295>
| asn <1-4294967295> |
Specify the ASN from 1 - 4294967295. |
nx9500-6C8809(config-profile NX9500Profile-router-bgp)#asn 1
nx9500-6C8809(config-profile NX9500Profile-router-bgp)#show context
router bgp
asn 1
