Removes a deny, permit, or disable rule
no [deny|disable|permit]
no [deny|permit] [<NETWORK-SERVICE-ALIAS-NAME>|icmp|ip|proto|tcp|udp] <RULE-PARAMETERS>
no disable [deny|permit] [<NETWORK-SERVICE-ALIAS-NAME>|icmp|ip|proto|tcp|udp] <RULE-PARAMETERS>
no [deny|permit] <NETWORK-SERVICE-ALIAS-NAME>icmp|ip|proto|tcp|udp] <RULE-PARAMETERS>
no [deny|permit] |
Removes a deny or permit rule from the selected IP access list |
<NETWORK-SERVICE-ALIAS-NAME> |
Removes a deny or permit rule applicable to the specified network-service alias
icmp |
Removes a deny or permit rule applicable to ICMP packets only |
ip |
Removes a deny or permit rule applicable to IP packets only |
proto |
Removes a deny or permit rule applicable to protocols (other than IP, ICMP, TCP, and UDP) |
[tcp|udp] |
Removes a deny or permit rule applicable to TCP/UDP packets |
<RULE-PARAMETERS> |
Enter the exact parameters used when configuring the rule. |
rule-precedence <1-5000> rule-description <LINE> |
Specify the precedence assigned to this deny/permit rule.
Note: The system removes the rule from the selected ACL. |
no disabled [deny|permit] |
Removes a disabled deny or permit rule from the selected IP access list |
Removes a disabled deny or permit rule applicable to the specified network-service alias
icmp |
Removes a disabled deny or permit rule applicable to ICMP packets only |
ip |
Removes a disabled deny or permit rule applicable to IP packets only |
proto |
Removes a disabled deny or permit rule applicable to protocols (other than IP, ICMP, TCP, and UDP) |
[tcp|udp] |
Removes a disabled deny or permit rule applicable to TCP/UDP packets |
<RULE-PARAMETERS> |
Specify the precedence assigned to this disabled deny/permit rule.
Note: The system removes the disabled rule from the selected ACL. |
Provide the rule-precedence value when using the no command.
The following example shows the ACL ‘test‘ settings before the ‘no‘ commands are executed:
<exsw1>(config-ip-acl-test)#show context
ip access-list test
deny proto vrrp any any log rule-precedence 600
deny proto ospf any any log rule-precedence 650
<exsw1>(config-ip-acl-test)#no deny proto vrrp any any rule-precedence 600
<exsw1>(config-ip-acl-test)#no deny proto ospf any any rule-precedence 650
The following example shows the ACL ‘test‘ settings after the ‘no‘ commands are executed:
<exsw1>(config-ip-acl-test)#show context ip access-list test <exsw1>(config-ip-acl-test)#
