Event system policies enable administrators to create notification mechanisms using one, some, or all of the SNMP, syslog, controller forwarding, or email notification options available to the controller or service platform. Each listed event can have customized notification settings defined and saved as part of an event policy. Thus, policies can be configured and administrated in respect to specific sets of client association, authentication or encryption, and performance events. Once policies are defined, they can be mapped to device profiles strategically as the likelihood of an event applies to particular devices.
To view an existing event system policy configuration details, use the show > event-system-policy command.
event-system-policy <EVENT-SYSTEM-POLICY-NAME>
| <EVENT-SYSTEM-POLICY-NAME> | Specify the event system policy name. If the policy does not exist, it is created. |
nx9500-6C8809(config)#event-system-policy event-testpolicy nx9500-6C8809(config-event-system-policy-event-testpolicy)#? Event System Policy Mode commands: event Configure an event no Negate a command or set its defaults clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-event-system-policy-event-testpolicy)#
| no | Removes an existing event system policy |
Print
this page
Email this topic
Feedback
