Enables dynamic routing (BGP and/or OSPF) and enters the routing protocol configuration mode
BGP is supported only on RFS4000, NX7500, and NX9500 model controllers and service platforms.The NX9500 service platforms do not support OSPF routing.
The access points only support OSPF routing.
router [bgp|ospf]
| router | Enables dynamic routing and enters the routing protocol configuration mode |
| bgp | Enables BGP dynamic routing and configures
relevant settings BGP is an inter-ISP routing protocol, which establishes routing between ISPs. ISPs use BGP to exchange routing and reachability information between AS (Autonomous Systems) on the Internet. BGP uses TCP as its transport protocol, eliminating the need to implement explicit update fragmentation, retransmission, acknowledgement, and sequencing. Routing information exchanged through BGP supports destination based forwarding only. It assumes a router forwards packets based on the destination address carried in the IP header of the packet. An AS is a set of routers under the same administration that use Interior Gateway Protocol (IGP) and common metrics to define how to route packets within the AS. For more information on dynamic BGP routing configurations, see Border Gateway Protocol . |
| ospf | Enables OSPF dynamic routing and configures
relevant settings. Changes configuration mode to router
mode OSPF is a link-state IGP. OSPF routes IP packets within a single routing domain (autonomous system), like an enterprise LAN. OSPF gathers link state information from neighbor routers and constructs a network topology. The topology determines the routing table presented to the Internet Layer which makes routing decisions based solely on the destination IP address found in IP packets. For more information on dynamic OSPF routing configurations, see Router Mode. |
nx9500-6C8809(config-profile-default-rfs4000)#router ospf nx9500-6C8809(config-profile default-rfs4000-router-ospf)#? Router OSPF Mode commands: area OSPF area auto-cost OSPF auto-cost default-information Distribution of default information ip Internet Protocol (IP) network OSPF network no Negate a command or set its defaults ospf Ospf passive Make OSPF Interface as passive redistribute Route types redistributed by OSPF route-limit Limit for number of routes handled OSPF process router-id Router ID clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-profile default-rfs4000-router-ospf)#
| no | Disables OSPF settings |
