Setting the default host management interface is not supported in interface configuration command mode accessed using the interface command. In release 7.0, the set ip interface command can be entered in any command mode and provides for the optional setting of the interface as the default host management interface. The set ip interface command also allows for the initial configuration of a non-routing IP interface that you can assign an IP address to using the set ip address command.
Print
this page
Email this topic
Feedback
