Syslog Terms and Definitions describes the Extreme Networks implementation of key Syslog components.
| Term | Definition | Extreme Networks Usage |
| Facility | Categorizes which functional process is generating an error message. Syslog combines this value and the severity value to determine message priority. | Extreme Networks uses the eight facility designations reserved for local use: local0 – local7. Default is local4, which allows the message severity portion of the priority code to be visible in clear text, making message interpretation easiest. For more information about facility designations, refer to RFC 3164. |
| Severity | Indicates the severity of the error condition generating the Syslog message. The lower the number value, the higher will be the severity of the condition generating the message. | Extreme Networks devices provide the following eight levels:
Note: Numerical
values used in Extreme Networks syslog CLI and the feature's configuration
MIB range from 1-8. These map to the RFC 3164 levels of 0-7 respectively.
Syslog messages generated report the RFC 3164 specified level values.
| Application | Client software applications running on devices that can generate Syslog messages. | Extreme Networks supported applications and their associated CLI mnemonic values include:
| Syslog server | A remote server configured to collect and store Syslog messages. | Extreme Networks devices allow up to 8 server IP addresses to be configured as destinations for Syslog messages. By default, Syslog server is globally enabled, with no IP addresses configured, at a severity level of 8. |
Print
this page
Email this topic
Feedback
