Example: Configuring and Monitoring Port Mirroring (S-, K-Series)
This section describes how to use Extreme Networks NetSight Console from a Network Management Station (NMS) to display RMON statistics for monitoring port mirroring.
- Log onto NetSight Console.
- On the console main screen, expand My Network in the file directory tree, right-click All Devices, and select Add Device.
The Add Device screen displays.
- Model the S- K- or 7100-Series device by entering its IP address in the field provided. Click OK.
- On the console main screen, expand All Devices in the file directory tree to show the IP address(es) of the device(s) you just modeled.
- Right-click on the IP address of the S- K- or 7100-Series device and select Device Manager.
- The device manager screen displays for the S-Series device.
- Right click on port 1 (ge.1.1) and select RMON Ethernet Statistics.
- Repeat step 9 for port 5 (ge.1.5).
RMON Ethernet statistics charts will display for ports 1 and 5.
- Note that the section of the two charts that shows the frame count by frame size lists no larger size frames (512-1518 bytes). In the next step, you will create large frames.
- Open the Command Prompt window and set up a continuous ping to the device, as shown below. Use -l 1400 to set the size of the ping frame to 1400 bytes and -t to set a continuous ping.
- Refer back to the RMON Ethernet Statistics windows opened in Steps 9 and 10. You should see the number of 1024 - 1518 frames incrementing on Port 1 because the NMS is connected on this port. You should also see that these larger size frames are not incrementing on Port 5.
- From the terminal session with the device, create a port mirroring instance with port 1 (ge.1.1) as the source and port 5 (ge.1.5) as the destination port.
System(su)->set port mirroring create ge.1.1 ge.1.5 both
- Verify the mirroring configuration.
System(su)->show port mirroring
Port Mirroring
Source Port = ge.1.1
Target Port = ge.1.5
Frames Mirrored = Rx and Tx
Port Mirroring Admin status = enabled
Port Mirroring Oper status = enabled
- Refer again to the RMON Ethernet Statistics windows and notice that both port 1 and port 5 are now incrementing the larger size frames. If you connected a network analyzer to port 5, you would see these frames being received and transmitted on port 1.
