Auto-negotiation is an Ethernet feature that facilitates the selection of port speed, duplex, and flow control between the two members of a link, by first sharing these capabilities and then selecting the fastest transmission mode that both ends of the link support. Auto-negotiation is enabled by default.
The advertised ability feature allows for the port to share its port capabilities with the other end of the link. Advertised capabilities will be used during the auto-negotiation process. Actual port capabilities, advertised port capability and remote end advertised port capabilities can be displayed using the show port advertise command in any command mode. The following port capabilities can be advertised:
Advertised ability can be activated only on ports that have auto-negotiation enabled.During auto-negotiation, making use of information gained from the advertised ability feature, the port “tells” the device at the other end of the segment what its capabilities and mode of operation are. If auto-negotiation is disabled, the port reverts to the values specified by the default speed, default duplex, and the port flow control commands.
Use the set port negotiation command to enable auto-negotiation on the specified ports.
Use the set port advertise command to specify the capabilities to be advertised on the specified ports.
The following example enables auto-negotiation on port ge.1.1 and sets the advertise utility to advertise 10BASE-T half duplex mode, 10BASE-T full duplex mode, 100BASE-TX half duplex mode, 100BASE-TX full duplex mode, and Asymmetric and Symmetric PAUSE for full-duplex links:
System(rw)->set port negotiation ge.1.1 enable System(rw)->set port advertise ge.1.1 10t 10tfd 100tx 100txfd bpause System(rw)->show port advertise ge.1.1 ge.1.1 capability advertised remote ---------------------------------------------- 10BASE-T yes yes yes 10BASE-TFD yes yes yes 100BASE-TX yes yes yes 100BASE-TXFD yes yes yes 1000BASE-X no no no 1000BASE-XFD no no no 1000BASE-T no no no 1000BASE-TFD no no no other no no no pause yes no yes Apause yes no no Spause yes no yes Bpause yes yes no System(rw)->
Print
this page
Email this topic
Feedback
