clear counters mpls
clear counters mpls {[lsp all | [{vlan} vlan_name | vlan all]]}
Description
Clears all packet and byte counters for all MPLS LSPs and all MPLS protocol counters for all MPLS interfaces.
Syntax Description
lsp all Clears all MPLS protocol counters for all MPLS LSPs.
vlan_name Clears all MPLS protocol counters for the MPLS interface on the specified VLAN.
vlan all Clears all MPLS protocol counters for all MPLS interfaces.
Default
N/A.
Usage Guidelines
This command clears all packet and byte counters for all MPLS LSPs and all MPLS protocol counters for all MPLS interfaces. If the lsp all keywords are specified, all packet and byte counters for all MPLS LSPs are cleared. If the vlan all keywords are specified, all MPLS protocol counters for all MPLS interfaces are cleared. If a VLAN name is specified, all MPLS protocol counters for the MPLS interface on that VLAN are cleared.
This example clears all MPLS counters associated with VLAN 1:
clear counters mpls vlan vlan_1
This command was first available in ExtremeXOS 11.6.
Platform Availability
This command is available only on the platforms that support this feature as described in the Switch Engine v33.6.1 Licensing Guide document.
