create erps ring
create erps ring-name {ring-id ring_id}
Description
Creates an ERPS ring.
Syntax Description
ring-name Alphanumeric string that identifies the ERPS ring.
ring-id Specifies configuring a unique integer ID for ERPS ring.
ring_id Sets the ERPS ring ID value. Range is 1 to 239.
Default
N/A.
Usage Guidelines
Use this command to create an ERPS ring, and optionally the ring ID.
The following command creates an ERPS ring named “ring1” with ring ID "50":
create erps ring1 ring-id 50
This command was first available in ExtremeXOS 15.1.
Ring ID was added in ExtremeXOS 33.6.1.
Platform Availability
