This command sets the priority used for DIS election on broadcast interfaces.
| vlan all | Applies the configuration to all IS-IS VLANs. |
| vlan_name | Specifies a single VLAN to which the configuration applies. |
| priority priority | Sets the priority value. The range is 0 to 127. |
| level [1 | 2] | Limits the configuration to either level 1 or level 2. If neither level 1 nor level 2 is specified, the configuration applies to both levels. |
64.
A higher priority value is preferred over a lower priority value. The priority is encoded in level 1 or level 2 hello PDUs. This command is not valid for point-to-point interfaces. Note that a priority of 0 has no special meaning other than the fact that it is the lowest priority. A router with a priority of 0 can still become the DIS.
The following command configures priority level 32 for SJvlan:
configure isis SJvlan priority 32
This command is available on all platforms with a Premier or Extreme Platform ONE license as described in the licensing guide.
