show ospf area
show ospf area {detail | area-identifier}
Description
Displays information about the OSPF area.
Syntax Description
detail Specifies to display the information in detailed format.
area-identifier Specifies an OSPF area.
Default
N/A.
Usage Guidelines
None.
The following is sample output from this command:
# show ospf area
AREA ID        Type Summ  Def   Num  Num  SPF  Num    LSA
Metric ABR  ASBR Runs LSAs   Checksum
0.0.0.0         NORM ---- ------ 0    0    0    0      0x0
Platform Availability
This command is available on all platforms with a Base license or higher as described in the licensing guide.
