Displays current software license level, port speed licensing, and feature packs enabled on your switches.
| all | Specifies all slots on a stack. |
| slot | Specifies one or more slots on a stack. |
| detail | Specifies showing detailed license information. ExtremeSwitching Universal switches only. |
N/A.
The command displays information on the software license level and feature packs enabled on the switch or nodes on a stack, including the trial license or factory default license and days left to expiry.
To see the license information on a SummitStack node, run the command while logged into that node.
See the specific chapter of the Switch Engine v33.6.1 User Guide that discusses each feature to determine if a license is required for some functionality. If not noted, all functionality is available, and license is not required.For ExtremeSwitching Universal switches, the DEF-EVAL-PRMR is a 30-day evaluation license that is enabled on the switch from the factory, or after changing the network operating to Switch Engine from Fabric Engine, or after a rescue boot.
The following command displays the license level configuration:
show licenses
On a SummitStack, the output from this command looks similar to the following:
Slot-3 Stack.12 > show licenses Enabled License Level: Advanced Edge Enabled Feature Packs: None Effective License Level:Edge
The show output also includes the current status of the non-Extreme optical device license:
# show license
Advanced Core
MPLS ServiceProviderEdge 3rdPartyOptics
To see all license levels on a stack:
Slot-1 Stack.6 # show licenses slot all
Slot Enabled License Effective License Feature Packs
1 Advanced Edge Advanced Edge DirectAttach
2 Advanced Edge Advanced Edge ServiceProviderEdge
DirectAttach
NetworkTiming
To view detailed license information on the ExtremeSwitching Universal switches:
# show licenses detail Slot License Product Feature(s) Installed Effective Expiration ---- ------------------ ---------- ---------- ---------- ------------------------ 1 DEF-EVAL-PRMR Premier Yes No Mon Sep 14 12:41:22 2020 1 PRD-5000-MACSEC MACsec No N/A N/A 2 PRD-5000-PRMR Premier No N/A N/A 2 PRD-5000-MACSEC MACsec Yes N/A Never 3 PRD-5000-PRMR Premier No N/A N/A 3 PRD-5000-MACSEC MACsec No N/A N/A
The following example displays Extreme Platform ONE license information (non-stack):
# show license
Standard
None
5720-48MXW-SwitchEngine.8 # show license detail
License Product Feature(s) Installed Expiration
STANDARD Standard Yes Thu Jul 25 21:46:08 2024
PRD-5000-PRMR Premier Yes Never
The following example displays Extreme Platform ONE license information (stack) with the detail option:
show lic det Slot License Product Feature(s) Installed Effective Expiration ---- ------------------ ---------- ---------- ---------- ------------------------ 1 STANDARD Standard Yes Yes Wed Feb 12 17:53:13 2025 1 PRD-5000-PRMR Premier No N/A N/A 1 PRD-5000-MACSEC MACsec No N/A N/A 2 STANDARD Standard Yes Yes Wed Feb 12 17:53:13 2025 2 PRD-5000-PRMR Premier No N/A N/A 2 PRD-5000-MACSEC MACsec No N/A N/A 3 STANDARD Standard Yes Yes Wed Feb 12 17:53:13 2025 3 PRD-5000-PRMR Premier No N/A N/A 3 PRD-5000-MACSEC MACsec Yes N/A Never
This command was first available in ExtremeXOS 11.1.
The information on enabled feature packs was added in ExtremeXOS 11.4.
The information on the trial licenses was added in ExtremeXOS 11.6.
The show output was updated to include the current status of the non-Extreme optical device license in ExtremeXOS 15.4.
The options all and slot were added in ExtremeXOS 22.5.
The detail option and ExtremeSwitching unified license information was added in ExtremeXOS 31.1.
Extreme Platform ONE license information was added in version 33.2.1.
