enable ripng export
enable ripng export [direct | ospfv3 | ospfv3-extern1 | ospfv3-extern2 | ospfv3-inter | ospfv3-intra | static | isis | isis-level-1| isis-level-1-external | isis-level-2| isis-level-2-external | bgp | e-bgp i-bgp] [cost number {tag number} | policy policy-name]
Description
Enables RIPng to redistribute routes from other routing functions.
Syntax Description
direct Specifies interface routes (only interfaces that have IP forwarding enabled are exported).
ospfv3 Specifies all OSPFv3 routes.
ospfv3-extern1 Specifies OSPFv3 external route type 1.
ospfv3-extern2 Specifies OSPFv3 external route type 2.
ospfv3-inter Specifies OSPFv3-inter area routes.
ospfv3-intra Specifies OSPFv3-intra area routes.
static Specifies static routes.
isis Specifies IS-IS routes.
isis-level-1 Specifies IS-IS Level 1 routes.
isis-level-1-external Specifies IS-IS Level 1 External routes.
isis-level-2 Specifies IS-IS Level 2 routes.
isis-level-2-external Specifies IS-IS Level 2 External routes.
bgp Specifies BGP IPv6 routes
e-bgpSpecifies EBGP routes.
i-bgpSpecifies IBGP routes.
cost numberSpecifies the cost metric, from 0-15. If set to 0, RIPng uses the route metric obtained from the route origin.
tag numberSpecifies a tag number.
policy-name Specifies a policy.
Default
Disabled. However, direct routes will always be advertised for all the interfaces where RIPng is enabled. For those interfaces where RIPng is not enabled, the corresponding direct route could be redistributed if direct route export is enabled through this command.
Default tag is 0.
Usage Guidelines
This command enables the exporting of static, direct, IS-IS, and OSPFv3-learned routes from the routing table into the RIPng domain. You can choose which types of IS-IS or OSPFv3 routes are injected, or you can simply choose isis or ospfv3, which will inject all learned routes (of all types) for the selected protocol.
The cost metric is inserted for all RIPng-learned, static, and direct routes injected into RIPng. If the cost metric is set to 0, the cost is inserted from the route table. The tag value is used only by special routing applications. Use 0 if you do not have specific requirements for using a tag.
Each protocol can have a policy associated with it to control or modify the exported routes. The following is sample policy file which modifies the cost of redistributed routes from OSPFv3 and statically configured routes:
entry filter_rt {
	If match any {
		Route-origin ospfv3;
		Route-origin static;
	then {
		cost 10;
The following command enables RIPng to redistribute routes from all OSPFv3 routes:
enable ripng export ospfv3 cost 0
Platform Availability
This command is available on platforms.
