disable rip triggerupdates
Description
Disables the trigger update mechanism. Triggered updates are a mechanism for immediately notifying a router‘s neighbors when the router adds or deletes routes or changes their metric.
Syntax Description
Default
Enabled.
Usage Guidelines
Triggered updates occur whenever a router changes the metric for a route and it is required to send an update message immediately, even if it is not yet time for a regular update message to be sent. This will generally result in faster convergence, but may also result in more RIP-related traffic.
The following command disables the trigger update mechanism:
# disable rip triggerupdate
Platform Availability
This command is available on all platforms with a Base license or higher as described in the licensing guide.
