enable rip aggregation
Description
Enables the RIP aggregation of subnet information on a RIP version 2 (RIPv2) interface.
Syntax Description
Default
Disabled.
Usage Guidelines
The enable (disable) rip aggregation command enables (disables) the RIP aggregation of subnet information on an interface configured to send RIPv1 or RIPv2-compatible traffic. The switch summarizes subnet routes to the nearest class network route. The following rules apply when using RIP aggregation:
  • Subnet routes are aggregated to the nearest class network route when crossing a class boundary.
  • Within a class boundary, no routes are aggregated.
  • If aggregation is enabled, the behavior is the same as in RIPv1.
  • If aggregation is disabled, subnet routes are never aggregated, even when crossing a class boundary.
The following command enables RIP aggregation on the interface:
# enable rip aggregation
Platform Availability
This command is available on all platforms with a Base license or higher as described in the licensing guide.
