configure isis restart
configure isis restart [ none | planned | unplanned | both ]
Description
This command configures IS-IS graceful restart behavior.
Syntax Description
none Disables IS-IS graceful restart. When graceful restart is disabled, this router still operates as a helper to other restarting routers.
planned Initiates IS-IS graceful restart only in response to the restart process isis.
unplanned Initiates graceful restart only when the IS-IS process is restarted due to a process crash or an unplanned failover.
both Initiates graceful restart for all events supported by the planned and unplanned options.
Default
None.
Usage Guidelines
The command options specify under which circumstances graceful restart is to be performed. This command has no effect during normal switch boot up. All IS-IS routing processes in the current virtual router are affected by this command.
All neighboring routers must support IS-IS restart in order for graceful restart to work. If graceful restart is not performed after a process restart or failover, the router's adjacencies are re-initialized causing SPF recalculation throughout the network and, if the overload bit is not configured to be set during startup, churn as adjacencies change state and LSPs are learned.
The planned and unplanned command options do not affect the actual restart protocol operation of IS-IS; they only determine when the restart process occurs.
The following command configures the switch to initiate a graceful restart for all events supported by the planned and unplanned options:
configure isis restart both
Platform Availability
This command is available on all platforms with a Premier or Extreme Platform ONE license as described in the licensing guide.
