disable snmp traps ospf
Description
Disables the OSPF module from sending traps on various OSPF events.
Syntax Description
Default
Disabled.
Usage Guidelines
None.
The following command disables the OSPF process:
This command was first available in ExtremeXOS 12.6.
Platform Availability
This command is available on all platforms with a Base license or higher as described in the licensing guide.
