show mpls interface
show mpls interface {{vlan} vlan_name} {detail}
Description
Displays the MPLS interface information. Information is displayed in tabular format for all VLANs that have been added to MPLS.
Syntax Description
vlan Specifies to display information for one VLAN.
vlan_name Specifies the name of the VLAN.
detail Specifies to display additional status information about the interface.
Default
N/A.
Usage Guidelines
Information displayed includes:
  • a list of all VLANs added to MPLS.
  • MTU size.
  • Local interface IP address.
  • Number of RSVP-TE neighbors.
  • Number of LDP adjacencies.
  • RSVP-TE and LDP uptimes.
  • MPLS protocols and capabilities configured on each VLAN.
Specifying the optional detail keyword displays the information in verbose form and also includes the operational state for RSVP-TE and LDP. Specifying a VLAN limits the output to that of the individual VLAN.
The following command display MPLS interface information:
Switch # show mpls interface
Local                  RSVP-TE      LDP
VLAN Name        IP Address      MTU   UpTm #Nbr UpTm  #Adj    Flags
loopb            11.100.100.218  1500    3h    0   3h    0     MRL-I-U
toratora         192.84.86.1     1500    3h    0   3h    1     MRL-IBU
tordoze          192.84.93.1     1500    3h    0   3h    1     MRL-IbU
torfour          192.84.83.1     1500    --    0   --    0     MRL-I--
torinasp         192.84.85.1     1500    --    0   --    0     MRL-I--
Flags: (M) MPLS Enabled, (R) RSVP-TE Enabled, (L) LDP Enabled,
(P) PHP Enabled, (I) IP Forwarding Enabled, (B) BFD Enabled,
(b) BFD Disabled(Sessions Exist) (U) MPLS Operational
The following command displays detailed MPLS information for VLAN 1:
# show mpls interface vlan1 detail
VLAN Name : vlan1
Local IP Address          : 192.84.86.1
IP Forwarding             : Enabled
MPLS I/F MTU              : 1500
PHP Status                : Disabled
BFD Status                : Enabled
MPLS Admin Status         : Enabled
MPLS Oper Status          : Disabled
RSVP-TE Admin Status      : Enabled
UpTime            : 0d:0h:0m:0s
# Neighbors       : 0
LDP Admin Status          : Enabled
# Link Adjacencies    : 0
This command was first available in ExtremeXOS 11.6.
The BFD flags and status were first available in ExtremeXOS 12.4.
Platform Availability
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.6.1 Licensing Guide document.
