show bgp evpn ipv4
show bgp evpn ipv4 {evi-index evi_index} {ip-address ip_address}
Description
Shows the IPv4 entries from the EVPN MAC/IP table.
Syntax Description
bgp Specifies BGP.
evpn Specifies Ethernet VPN (RFC 7432).
ipv4 Shows only the IPv4 entries from the EVPN MAC/IP table.
evi-index Specifies the EVI index.
evi_index Restricts the display to EVI index (should be equal to VLAN ID). Range is 1 to 4,094.
ip-address Restricts the display to an IP address.
ip_address Selects the IP address.
Default
N/A.
Usage Guidelines
This command allows you to view the current set of IPv4 addresses configured in EVPN. If the ESI and ESI-Port fields are non-zero, then the entry was learned over a shared interface. The remote LACP partner‘s 6-byte MAC address is part of the ESI. For a full decoding of the ESI, see RFC 7432. The source (Src) column indicates whether the entry was learned (L)ocally or (R)emotely. The local entries are from the IP ARP cache or a locally configured routable VLAN. The remote entries appear only if the “In Use” flag is set to yes.
The following example shows the current set of IPv4 addresses configured in EVPN.
# show bgp evpn ipv4
Src EVI-Idx Destination     MAC               BGP Next Hop           VNI ESI                            ESI-Port   In Use
L       190 192.168.190.102 00:04:96:9d:64:e2                      10000 00:01:02:03:04:05:06:07:08:09  22         Yes
R       190 192.168.190.101 00:04:96:9d:66:e8 3.3.3.103            10000                                           Yes
R      1020 20.1.1.3        00:04:96:9c:2c:a2 1.1.1.101           101020                                           Yes
L      1020 20.1.1.1        00:04:96:9d:64:e2                     101020                                           Yes
R      1020 20.1.1.2        00:04:96:9d:66:e8 3.3.3.103           101020                                           Yes
L      3500 1.1.103.1       00:04:96:9d:64:e2                     111103                                           Yes
R      4089 21.1.1.3        00:04:96:9c:2c:a2 1.1.1.101           101021                                           Yes
L      4089 21.1.1.1        00:04:96:9d:64:e2                     101021                                           Yes
R      4089 21.1.1.2        00:04:96:9d:66:e8 3.3.3.103           101021                                           Yes
R      4089 21.1.1.30       00:0f:20:98:87:5a 3.3.3.103           101021                                           Yes
Src: (L) Local, (R) Remote
In Use: Yes/No - Indicates if entry is installed in IP ARP cache.
Total MAC/IP entries: 10
This command was first available in ExtremeXOS 30.2.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.6.1 Licensing Guide document.
