show msrp
show msrp
Description
Displays the MSRP configuration on the switch.
Syntax Description
msrp Multiple Stream Registration Protocol.
Default
N/A.
Usage Guidelines
Use this command to display MSRP configuration on the switch.
# show msrp
MSRP Status                             : Enabled
MSRP Max Latency Frame Size             : 1522
MSRP Max Fan-in Ports                   : No limit
MSRP First Value Change Recovery Time   : 10000 (ms)
MSRP Ignore Latency Changes             : On
MSRP Talker VLAN Pruning                : On
MSRP Enabled Ports                      : *17ab       *19a    !5
Total MSRP streams                      : 4
Total MSRP reservations                 : 2
Flags:    (*) Active,             (!) Administratively disabled,
          (a) SR Class A allowed, (b) SR Class B allowed.
This command was first available in ExtremeXOS 15.3.
The MSRP First Value Change Recovery Time, MSRP Ignore Latency Change, and MSRP Talker VLAN Pruning example outputs were added in 15.3.2.
Platform Availability
This command is available on all platforms that support the AVB feature and that have an AVB feature pack license installed. To see which platforms support AVB and for information about obtaining a license, see the Switch Engine v33.6.1 Licensing Guide .
