show ospfv3 area
show ospfv3 area {area_identifier | detail}
Description
Displays information about OSPFv3 areas.
Syntax Description
area_identifier Specifies an OSPFv3 area, a four-byte, dotted decimal number.
detail Specifies to display the information in detailed format.
Default
N/A.
Usage Guidelines
None.
The following command displays summary information about the OSPFv3 areas:
show ospfv3 area
The following is sample output:
AREA ID        Type Summ  Def   Num  Num  Num  SPF  Num    LSA
Metric ABR  ASBR Intf Runs LSAs   Checksum
0.0.0.0         NORM ---- ------ 0    0    1    7    7      0x3155b
1.0.0.0         NORM ---- ------ 1    1    1    6    9      0x4793d
2.0.0.0         NORM ---- ------ 0    0    1    5    10     0x47174
3.0.0.0         NORM ---- ------ 1    0    1    3    12     0x420cf
5.0.0.0         NORM ---- ------ 1    0    1    4    10     0x3b5b1
The following command displays information about OSPFv3 area 1.0.0.0:
show ospfv3 area 1.0.0.0
Area Identifier     : 1.0.0.0            Type                : NORM
Router ID           : 20.0.0.1           Num of Interfaces   : 1
Spf Runs            : 6                  Num ABRs            : 1
Num ASBRs           : 1                  Num DC-Bit LSAs     : 1
Num Indication LSAs : 1                  Num of DoNotAge LSAs: 1
Num LSAs            : 9                  LSA Chksum          : 0x4793d
Num of Nbrs         : 1                  Num of Virtual Nbrs : 0
Interfaces:
Interface Name                  Ospf State    DR ID           BDR ID
to65                            E    BDR      0.0.0.65        20.0.0.1
accounts                        E    DR       80.0.0.5        0.0.0.0
finance                         E    BDR      90.0.0.7        66.0.0.4
engineering                     E    ODR      192.168.0.1     165.0.0.3
Corporate                       E    ODR      201.0.16.6      204.0.0.1
Inter-Area route Filter: ospfSummPolicy
External route Filter: ospfExtPolicy
Configured Address Ranges:
Addr: fffe:408:1449::/48 Type: 3 Advt: Yes
Addr: ffe0:930:2781::/40 Type: 7 Advt: No
Platform Availability
This command is available on all platforms with a Base license or higher as described in the licensing guide.
