show igmp group
show igmp group {{vlan} {name} | {grpipaddress}} {IGMPv3}
Description
Lists the IGMP group membership for the specified VLAN.
Syntax Description
name Specifies a VLAN name.
grpipaddress Specifies a group IP address.
IGMPv3 Displays the IGMP group in IGMPv3 format (if group record is IGMPv3 compatible, otherwise displays in earlier format).
Default
IGMPv2.
Usage Guidelines
If no VLAN is specified, all VLANs are displayed. You can also filter the display by group address or by multicast stream sender address.
The output of this command shows:
The following is sample output from the show igmp group command, listing the IGMP group membership:
Group Address     Ver Vlan                 Port      Age
239.2.4.70        2   banana               7         101
224.0.1.24        2   banana               7         107
239.255.255.254   2   banana               7         103
Total: 3
The IGMPv3 option was added in ExtremeXOS 11.2.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the IPv4 multicast feature, see the Switch Engine v33.6.1 Licensing Guide document.
