Displays a summary of the BGP route information base (RIB).
| ipv4-unicast | Specifies the IPv4 unicast address family. |
| ipv4-multicast | Specifies an IPv4 multicast address family. |
| ipv6-unicast | Specifies the IPv6 unicast address family. |
| ipv6-multicast | Specifies an IPv6 multicast address family. |
| vpnv4 | Specifies the VPNv4 address family for Layer 3 VPN support. |
| ipv4-vxlan | Specifies an IPv4 VXLAN address family. |
| vr | Specifies viewing routes associated with a specified virtual router. |
| vr_name | Specifes the VR name. If not specified, the VR of current command context is used. |
If no address family is specified, IPv4 unicast is the default.
If you do not specify an address family, this command applies to the IPv4 unicast address family. To apply this command to an address family other than the IPv4 unicast address family, you must specify the address family.
To display Layer 3 VPN information, you must enter this command in the context of on the MPLS-enabled VR; it is not supported for BGP neighbors on the CE (VRF) side of the PE router.
When the show bgp routes summary command is issued with address-family vpnv4, the command will impact the behavior of PE to PE neighbor sessions and display/clear the VPN-IPv4 RIB of BGP.
The following command displays a summary of the BGP route information base (RIB) for IPv4 multicast:
show bgp routes address-family ipv4-multicast summary
The following example displays VPN routes with RD 100:1:
virtual-router corp1_vrf
show bgp routes address-family vpnv4 rd 100:1
Support for IPv6 was added in ExtremeXOS 12.6 BGP.
Support for Layer 3 VPNs was added in ExtremeXOS 15.3.
Support for IPv4 VXLAN was added in ExtremeXOS 22.3.
Support for user-specified VRs was added in ExtremeXOS 30.3.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.6.1 Licensing Guide document.
