show mld group
show mld group {{vlan} {name} | {v6grpipaddress}} {MLDv2}
Description
Lists the MLD group membership for the specified VLAN or group.
Syntax Description
name Specifies a VLAN name.
v6grpipaddress Specifies a group IPv6 address.
MLDv2 DisplayS the MLD group in MLDv2 format (if group record is MLDv2 compatible, otherwise displayS in earlier format). This option is not supported in this release.
Default
MLDv1.
Usage Guidelines
If no VLAN is specified, all VLANs are displayed. You can also filter the display by group address or by multicast stream sender address.
The following command lists the MLD group membership for the VLAN accounting:
show mld group vtest3
Output from this command looks similar to the following:
Group Address               Ver Vlan            Port   Age
ff03::1:1                   1   vtest3          4:5    25
ff03::1:2                   1   vtest3          4:5    25
ff02::1:ff22:124            1   vtest3          4:45   26
ff05::a:abcd                1   vtest3          4:15   23
ff05::a:abce                1   vtest3          4:15   23
ff02::1:ff22:112            1   vtest3          4:45   26
ff02::1:ff1f:a418           1   vtest3          4:45   26
Platform Availability
This command is available on the platforms listed for the IPv6 multicast routing feature in the Switch Engine v33.6.1 Licensing Guide document.
