Disables the split horizon algorithm for RIP.
This command has no arguments or variable.
Enabled.
Split horizon is a scheme for avoiding problems caused by including routes in updates sent to the router from which the route was learned. Split horizon omits routes learned from a neighbor in updates sent to that neighbor.
The following command disables the split horizon algorithm for RIP:
# disable rip splithorizon
This command is available on all platforms with a Base license or higher as described in the licensing guide.
