show ripng
show ripng
Description
Displays RIPng global configuration and runtime information.
Syntax Description
Default
N/A.
Usage Guidelines
None.
The following command displays RIPng global configuration and runtime information:
show ripng
The following is sample output from this command:
RIPng Routing    : Disabled
Aggregation      : Disabled
Update Interval  : 30                Route Timeout     : 180
Garbage Timeout  : 120
Originate Default: Disabled
Sys Import-Policy: None
Redistribute:
Protocol        Status    Cost Tag    Policy
Direct          Disabled  0    0      none
Static          Disabled  0    0      none
Ospfv3-intra    Disabled  0    0      none
Ospfv3-inter    Disabled  0    0      none
Ospfv3-extern1  Disabled  0    0      none
Ospfv3-extern2  Disabled  0    0      none
IsisL1          Disabled  0    0      none
IsisL2          Disabled  0    0      none
IsisL1Ext       Disabled  0    0      none
IsisL2Ext       Disabled  0    0      none
bgp 		   Disabled  0 0      none
Platform Availability
This command is available on platforms with an Edge, Advanced Edge, or Core license. For licensing information, see the Switch Engine v33.6.1 Licensing Guide document.
