configure inline-power classification
configure inline-power classification [802.3af | 802.3af-high | 802.3pre-at | 802.3at | 802.3pre-bt | 802.3bt-type3 | 802.3bt-type4] ports port_list
Description
This command configures PoE port-level classification power-up mode for Extreme Networks PoE devices that do not support 802.3bt when connecting to switches with 60W/90W PoE ports. ExtremeSwitching platforms support per-port basis configuration.
Syntax Description
classificationClassification power-up mode.
802.3afIEEE 802.3af 15W mode.
802.3af-highIEEE 802.3af 30W mode.
802.3pre-atIEEE 802.3 pre-at 30W mode.
802.3at IEEE 802.3at 30W mode.
802.3pre-btIEEE 802.3 pre-bt 4-pair 60W mode.
802.3bt-type3IEEE 802.3bt Type 3 60W mode.
802.3bt-type4IEEE 802.3bt Type 4 90W mode.
portsSpecifies the port.
port_listPort list separated by a comma or - .
Default
Depends on the maximum classification level supported by the platform. For example, one switch can have a default classification level of 802.3bt-type4, while another a default classification level of 802.3at.
Usage Guidelines
Use the specified power-up classification instead of the default classification based on port type.
The following command displays all classification options:
# configure inline-power classification ?
  802.3af         IEEE 802.3af 15W mode
  802.3af-high    IEEE 802.3af 30W mode
  802.3bt-type3   IEEE 802.3bt Type 3 60W mode
  802.3bt-type4   IEEE 802.3bt Type 4 90W mode
  802.3pre-at     IEEE 802.3 pre-at 30W mode
  802.3pre-bt     IEEE 802.3 pre-bt 4-pair 60W mode
This command was first available in ExtremeXOS 31.3.
The 802.3af, 802.3af-high, and 802.3pre-at options were added in ExtremeXOS 31.7.
Platform Availability
PoE
