disable isis
disable isis {area area_name}
Description
This command disables the specified IS-IS router process on the current virtual router.
Syntax Description
area_name Specifies the name of the IS-IS router process to be disabled.
Default
Disabled.
Usage Guidelines
IS-IS PDUs are no longer sent or processed on this IS-IS router process. The LSP and neighbor databases are purged. IS-IS routes are purged from the routing table. This command should only be used during planned network outages. This command has no effect on router processes that are already disabled.
The following command disables the IS-IS process named areax:
disable isis area areax
Platform Availability
This command is available on all platforms with a Premier or Extreme Platform ONE license as described in the licensing guide.
