show pim cache
show pim { ipv4 | ipv6 } cache {{detail} | {state-refresh} {mlag-peer-info} {group_addr {source_addr}}}
Description
Displays the multicast cache entries created by PIM.
Syntax Description
ipv4 Displays IPv4 PIM information
ipv6 Displays IPv6 PIM information.
detail Specifies to display the information in detailed format.
group_addr Specifies an IP group address.
source_addr Specifies an IP source address.
state-refresh Specifies to display the PIM cache entries with state refresh parameters.
mlag-peer-info Shows This command is available on all Universal switches supported in this document. peer related information.
Default
N/A.
Usage Guidelines
Displays the following information:
When the detail option is specified, the switch displays the egress VLAN list and the pruned VLAN list.
The following command displays the PIM cache entry for group 239.255.255.1:
Switch.33 # show pim cache 239.255.255.1
Index  Dest Group      Source             InVlan   Origin
[0000] 239.255.255.1   124.124.124.124 (WR) v4    Sparse
Entry timer is not run; UpstNbr: 200.124.124.24
EgressIfList =  vbs15(0)(FW)(SM)(I)
[0001] 239.255.255.1   118.5.1.1 (S)      vbs5  Sparse
Expires after 186 secs UpstNbr: 0.0.0.0
RP: 124.124.124.124 via 200.124.124.24 in v4
EgressIfList =  vbs15(0)(FW)(SM)(I) , vpim5(170)(FW)(SM)(S)
PrunedIfList =  v4(0)(SM)
Number of multicast cache = 20
Entry flags :-
R: RP tree. S: Source tree. W: Any source.
Egress/Pruned interface flags :-
SM: Sparse Mode           DM: Dense Mode
Fw: Forwarding            PP: Prune pending
AL: Assert Loser           N: Neighbor present
I: IGMP member present    S: (s,g) join received
Z: (*,g) join received    Y: (*,*,rp) join received
The following command displays the PIM-DM cache entry with state-refresh information for group 225.0.0.1:
Switch.5 # show pim cache state-refresh 225.0.0.1
[0001] 225.0.0.1       64.1.1.100 (S)     vixia    Dense   Not Pruned
Expires after 204 secs UpstNbr: 0.0.0.0
Refresh State: Originator(20), TTL: 16
EgressIfList =  v36(0)(FW)(DM)(N)
[0001] 225.0.0.1       65.1.1.100 (S)     vixia    Dense   Not Pruned
Expires after 195 secs UpstNbr: 65.1.1.200
Refresh State: Not-Originator(25), TTL: 8
The following command displays the ingress VLAN information of all MLAG peers:
* (pacman debug) sw6.2 # show pim c mlag-peer-info
[0000] 226.1.1.1       61.2.2.2 (WR)      fifthteen Sparse
       Entry timer is not run; UpstNbr: 51.15.15.2
       Peer Ingress VLAN (ISC 1): 51.15.15.4/24 (Same)
       EgressIfList =  eight(0)(FW)(SM)(I) , five(0)(FW)(SM)(I) , ten(0)(FW)(SM)(I)
[0001] 226.1.1.1       112.2.2.202 (S)    fifthteen Sparse
       Expires after 203 secs UpstNbr: 51.15.15.2
       RP: 61.2.2.2 via 51.15.15.2 in fifthteen
       PrunedIfList =  ten(0)(SM)(AL)
This command was modified in ExtremeXOS 15.2 to display MLAG peer information.
The ipv4 and ipv6 keyword options were added in ExtreameXOS 15.3.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM feature, see the Switch Engine v33.6.1 Licensing Guide document.
