disable iproute protection ping
disable iproute {ipv4 | ipv6} protection ping
Description
Globally disables ping protection for static routes added with ping protection for IPv4 and IPv6. Routes are up in the routing table, and ping health check monitoring is not performed.
Syntax Description
ipv4 Specifies IPv4 (default).
ipv6 Specifies IPv6.
protectionDisables route protection.
pingGlobally disables ping protection for static routes added with ping protection (default is enabled).
Default
Enabled is the default. If not specified, IPv4 is the default.
The following example disables ping protection for static routes added with ping protection for IPv4:
# disable iproute ipv4 protection ping
This command was first available in ExtremeXOS 22.1.
Platform Availability
