configure isis mesh
configure isis [vlan all | {vlan} vlan_name] mesh [block-none | block-all | block-group group_id]
Description
This command configures LSP flooding behavior for the specified interface.
Syntax Description
vlan all
Applies the configuration to all IS-IS VLANs.
vlan_name
Specifies a single VLAN to which the configuration applies.
block-none
Disables LSP blocking.
block-all
Blocks all LSPs. No LSPs are flooded out of the selected interface.
block-group
Blocks LSPs that contain the specified group ID.
group_id
Specifies a group ID number. The range is 1 to 4294967295.
Default
Block-none.
Usage Guidelines
In a mesh environment, which is a set of fully interconnected point-to-point interfaces, LSP flooding can generate N2 PDUs because no router can tell which routers have and have not received the flooded LSP. By carefully selecting the links over which LSPs are flooded, traffic can be greatly reduced at the cost of some resiliency. Using mesh group IDs instead of a full block (the block-all option) allows a finer granularity of control.
The following command configures blocking on SJvlan for group 5:
configure isis SJvlan mesh block-group 5
Platform Availability
This command is available on all platforms with a Premier or Extreme Platform ONE license as described in the licensing guide.
