configure syslog delete
configure syslog delete [ ipaddress {udp-port {udp_port}} | ipPort | ipaddress tls_port {tls_port}] {vr vr_name} [local0...local7 ]] | all {local0...local7} {vr vr_name} ]
configure syslog delete host name/ip {: udp-port} [local0...local7]
Description
Deletes a remote Syslog server address.
Syntax Description
ipaddress Specifies the remote Syslog server IP address.
ipPort Specifies the UDP port number for the Syslog target.
tls_port Specifies remote Syslog server Transport Layer Security (TLS) for connection type.
tls_port TLS port number.
vr_name Specifies the virtual router that can reach the server IP address.
Note: User-created VRs are supported only on the platforms listed for this feature in the Switch Engine v33.6.1 Licensing Guide document.
local0 ... local7 Specifies the local Syslog facility.
all Specifies all remote Syslog servers.
Default
If a virtual router is not specified, VR-Mgmt is used.
If a UDP port number is not specified, 514 is used.
If a TLS port number is not specified, 6514 is used.
Usage Guidelines
This command is used to delete a remote Syslog server target.
The following example deletes the remote Syslog server with an IP address of 10.0.0.1:
configure syslog delete 10.0.0.1 local1
The following example deletes the remote Syslog server with an IP address of 2001:11::123 :
configure syslog delete 2001:11::123  local1
The ipPort parameter was first available in ExtremeXOS 11.0.
The udp-port parameter and support for the EMS to send log messages to Syslog servers having IPv6 address was added in ExtremeXOS 21.1.
Transport Layer Security (TLS) option added in ExtremeXOS 22.1.
Platform Availability
