disable pim ssm vlan
disable pim {ipv4 | ipv6} ssm vlan [vlan_name | all]
Description
Disables PIM SSM on a router interface.
Syntax Description
ipv4 Specifies the IPv4 address family.
ipv6 Specifies the IPv6 address family.
vlan_name Specifies a VLAN name.
all Specifies all VLANs.
Default
Disabled on all interfaces.
Usage Guidelines
This command disables PIM-SSM on the specified Layer 3 VLAN.
IGMPv3 include messages for multicast addresses in the SSM range is only processed by PIM if PIM-SSM is enabled on the interface. Any non-IGMPv3 messages in the SSM range are not processed by PIM on any switch interface, whether SSM is enabled or not.
The following example disables PIM-SSM multicast routing on VLAN accounting:
disable pim ssm vlan accounting
This command was first available in ExtremeXOS 11.4.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM feature, see the Switch Engine v33.6.1 Licensing Guide document.
