configure rip updatetime
configure rip updatetime seconds
Description
Specifies the time interval in seconds within which RIP sends update packets.
Syntax Description
seconds
Specifies a time in seconds. The range is 10 to 180.
Default
30 seconds.
Usage Guidelines
The router exchanges an update message with each neighbor every 30 seconds (default value) or if there is a change to the overall routed topology (also called triggered updates). The timer granularity is 10 seconds. Timer minimum is 10 seconds and maximum is 180 seconds.
The following command sets the update timer to 60 seconds:
# configure rip updatetime 60
Platform Availability
This command is available on all platforms with a Base license or higher as described in the licensing guide.
