Disables automatic start-up of guest virtual machines (VMs).
| vm | Designates a virtual machine. |
| vm_name | Specifies the VM name. |
| autostart | Specifies disabling automatic start-up of the specified VM. Default is disabled. |
By default, automatic start-up is disabled.
This command disables automatically starting up a specific VM when the system starts.
You must reboot the switch for this command to take effect.
To enable automatic start-up, use the command enable vm vm_name autostart.
The Integrated Application Hosting (IAH) feature requires the Solid State Storage Device SSD-120.
The following example disables automatic start-up of VM "vm1":
# disable vm vm1 autostart
This command was first available in ExtremeXOS 30.3.
This command is available on all platforms that support the Integrated Application Hosting (IAH) feature and have a Premier or Extreme Platform ONE license installed. For a list of platforms that support the IAH feature and for information about licenses, see the Switch Engine v33.6.1 Licensing Guide .
