configure ipmroute delete
configure ipmroute delete [default | source-net/mask-len | source-net mask] {{protocol} protocol} rpf-address {vr vr-name}
Description
Deletes a static multicast address from the multicast routing table.
Syntax Description
default Specifies default gateway.
source-net Specifies an IP address/mask length.
mask-len Mask length for the IP multicast source's subnet. Range is 1–32.
mask Specifies a subnet mask.
protocol Unicast routing protocol that is to be used for route learning.
rpf-address Next hop through which the multicast source can be reached.
vr-name Specifies the virtual router to which the route is added.
Default
vr-name is the VR of the current CLI context.
Usage Guidelines
This command allows you to delete an existing multicast static route. It allows you to configure congruent topology for unicast and multicast packets and traffic.
The following example deletes a multicast static route:
configure ipmroute delete 192.168.0.0/16 192.75.0.91
This command was first available in ExtremeXOS 11.6.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the IPv4 multicast feature, see the Switch Engine v33.6.1 Licensing Guide document.
