show qosprofile
show qosprofile {ingress | egress} [ports [port_list | all | port_group] | NULL]
Description
Displays QoS information on the switch.
Syntax Description
ports Specifies to show ports.
port_list Specifies a list of ports.
port_groupSpecifies the port group name.
all Specifies all ports.
NULLNULL.
Default
Displays egress QoS information for all ports.
Usage Guidelines
The displayed QoS profile information differs depending on the platform you are running on. The following section shows examples for different platforms.
The display varies depending on your platform.
The following shows the information that appears when you omit the optional port parameter:
# show qosprofile
QP1    Weight =  1     Max Buffer Percent = 100
QP2    Weight =  1     Max Buffer Percent = 100
QP8    Weight =  1     Max Buffer Percent = 100
The following example shows how the display appears when the switch is configured for weighted-round-robin mode and some QoS profiles are configured for strict priority mode:
# show qosprofile
QP3    Weight =  1     Max Buffer Percent = 100
QP5    Strict-Priority Max Buffer Percent = 100
QP8    Strict-Priority Max Buffer Percent = 100
When you add the optional port parameter, the switch displays the following sample output:
# show qosprofile ports 33
Port: 33
    QP1  MinBw =       0%  MaxBw =     100%  MaxBuf =   100%  Weight =    1
    QP2  MinBwActl =  20%  MaxBwActl =  80%  MaxBuf =   100%  Weight =    1
    QP8  MinBw =       0%  MaxBw =     100%  MaxBuf =   100%  Weight =    1
This last sample output is not available on the XGS2 ports.
When you add the optional port group, the switch displays the following sample output:
# show qosprofile ports qosGroupA
Group: qosGroupA
Ports: 1-3
QP3  MinBw =     0% MaxBw        =    34% MaxBuf =   100% Weight =   1
QP4  MinBw =     0% MaxBw        =    10% MaxBuf =   100% Weight =   1
QP5  MinBw =     0% MaxBw        =     1% MaxBuf =   100% Weight =   1
The ingress information was added in ExtremeXOS 11.0.
minbw_actual and maxbw_actual information was added in version 33.3.1.
Platform Availability
